telefunken: 5351W; Jubilate
? telefunken: 5351W; Jubilate
05.Jan.13 09:14
40
Peter Radolla (CDN)
Articles: 5
Count of Thanks: 28
    Hello fellow collectors :    I have a problem downloading the schematics for the Telefunken Model : Jubilate 5351W.    Perhaps someone in the Radio Museum Land could point me in the right direction to aquire the schematics.  I got this radio recently and like to check it out.   Thanks  Peter R.
Schematic download
05.Jan.13 14:44
40 from 2711
Martin Bösch (CH)
Articles: 612
Count of Thanks: 19
Martin Bösch
Hallo Peter, to download schematics follow these steps:
- first: your UACS points score should be low: as I have seen, this is the case. You did already upload a few images, so you won't have to worry about this
- next: go to the model page, click on the first schematic (right upper small window), so a preview (which will allow you to check the quality) will appear in the left slightly bigger window. Click into that window and the PDF will be opened.
You will need to have a PDF viewer installed on your computer: in most cases this is the Acrobat plugin for our favourite browser. This will open in the same window and display the schematic.
I have chosen a slightly different way, as I use not Acrobat reader but the Foxit Reader (which is free to download and a quick and small software), and I have set the options in the browser menu to open it in a new window.
- alternative: use the dropdown menu "Documents" in the browser, a new window with all available schematics wil open.
Use a right mouse click on the file to get a context menu and use the command "Save target as..." (or similar, my windows is in german language) and save the files on a desktop or a suitable folder.
From there you can re-open the file as many times as you like without using UACS points for the same schematic again. This is very useful if you want to make a documentation of the schematics of all your sets or need the schematic later again, e.g. for a ongoing restoration.
Hope this helps, kind regards
Martin
