telefunken: 7 Licensed by Armstrong; Opus :
? telefunken: 7 Licensed by Armstrong; Opus :
Dear Members,
I have been working on the restoration of a Telefunken Opus 7.
Per schematics, screen voltage of EF89 in the last IF stage (tube4) should be 25V but I read 40V. All the components around EF89 are OK (C48,C47,W20,W21,C38 and grid resistor).
Anode voltage is around 220V which should be OK as well.
I swapped the EF89 with the one in previous IF stage (which shows the correct voltage values so I assume it is a good tube), still I read 40V. I have tried 3 different EF89s from other radios I have, the result is same.
Any thoughts about this issue?
Thanks in advance,
Cuneyt
Voltmeter resistance
In the '50ies when the Telefunken Opus was produced, voltmeters usually had an internal resistance of 333Ω/V, and some had 1kΩ/V. Today digital voltmeters read 10MΩ.
The voltages given in the schematic were measured with voltmeters of that time.
However, the internal resistance of a voltmeter loads the measured object. Therefore former low impedance voltmeters read lower values than modern digital voltmeters do.
Regards,
Dietmar
