telefunken: 7 Licensed by Armstrong; Opus :
? telefunken: 7 Licensed by Armstrong; Opus :
25.Jun.15 01:46
47
Cuneyt Bakan (USA)
Articles: 12
Count of Thanks: 7
Dear Members,
I have been working on the restoration of a Telefunken Opus 7.
Per schematics, screen voltage of EF89 in the last IF stage (tube4) should be 25V but I read 40V. All the components around EF89 are OK (C48,C47,W20,W21,C38 and grid resistor).
Anode voltage is around 220V which should be OK as well.
I swapped the EF89 with the one in previous IF stage (which shows the correct voltage values so I assume it is a good tube), still I read 40V. I have tried 3 different EF89s from other radios I have, the result is same.
Any thoughts about this issue?
Thanks in advance,
Cuneyt
Voltmeter resistance
25.Jun.15 16:11
47 de 2171
Articles: 2441
Count of Thanks: 8
In the '50ies when the Telefunken Opus was produced, voltmeters usually had an internal resistance of 333Ω/V, and some had 1kΩ/V.  Today digital voltmeters read 10MΩ.
The voltages given in the schematic were measured with voltmeters of that time.
However, the internal resistance of a voltmeter loads the measured object. Therefore former low impedance voltmeters read lower values than modern digital voltmeters do.
Regards,
Dietmar
