pilot: Too many tubes
? pilot: Too many tubes
15.May.17 18:48
24
Victor Ford (USA)
Articles: 3
Count of Thanks: 23
The Pilotuner T601 schemetic shows 5 tubes/valves. Mine has a 6th tube under the chassis. A 6C4. Not sure where to go from here. I replaced all caps, and all 6 tubes are good. Just trying to figure out why the 6C4?
Pilotuner T601 with 6 tubes?
15.May.17 20:19
24 from 3956
Officer
Articles: 1744
Count of Thanks: 25
Hello Victor,
please show some pictures of your Pilotuner T601 to help determine if this is an original factory variant or a later modification.
Thank you.
06.Jun.17 10:25
316 from 3956
Robert Weaver (CDN)
Articles: 35
Count of Thanks: 29
I've never seen any documentation to indicate that there was ever a version with an added 6C4. I think that this was likely a user modification, not done at the factory. It's not normal for a factory built product to have a tube mounted under the chassis. As Bernhard suggested, a picture would be very helpful.
Off the top of my head I can think of a couple of reasons for adding this tube. The most likely is to get a bit more audio output. The other possibility (less likely) is that it is part of an added AFC circuit.
