triplett: 666-HH; Volt-Ohm-Meter (VOM)
03.Mar.13 23:19
2575
Robert Forbes (AUS)
Articles: 4
Count of Thanks: 4
I have just repaired a 666H which had on the inside of the case the date of 1943.
The meter had been dropped and a cracked case repaired reasonably well but the dial glass was damaged, I have replaced that with a piece of a audio cassette case for the time being.
Tested in comparison against a modern DMM, the readings are very good.
