Unknown metal-mazda valve
? Unknown metal-mazda valve
17.Jul.17 18:09
33
Nicolaas van Dijk (CR)
Articles: 41
Count of Thanks: 18
Nicolaas van Dijk
I have a valve, clearly an indirected heated triode with a 4 pin European base and two side contacts. The barnd says MetalMazda with a common M.
I can´t read the complete number, what I can read is BV?604.
Also stated at the ballon is 2.5 V and 150 V
The interior is a round anode and grid like the A415 with approx. the same dimension, but a indirected heated cathode
Anyone an idea?
Regards
Nico
17.Jul.17 23:18
33 von 3181
Wolfgang Holtmann (NL)
Articles: 996
Count of Thanks: 16
Wolfgang Holtmann
Hello
I think the correct type is BW604.
It is indeed an indirectly heated triode for AC supply via the side contacts.
This was done to replace the old directly heated triodes (by a storage battery) in a wireless set.
You have simply to add a transformer fed from the mains.
Kind regards.
17.Jul.17 23:40
39 von 3181
Articles: 41
Count of Thanks: 21
Nicolaas van Dijk
So the question mark is the other half of the W!!
Thanks a lot for the info Wolfgang, highly appreciated. I will mark the tube as such
I saw it is from 1928, nice
Kind regards
Nico
