Unknown radio
? Unknown radio
Co-workers! Unknown radio, very bad picture. Zoomed in a little, the speaker grille is familiar. Anyone recognize it or be home-made? Br, STS
Attachments:- radio photo (7 KB)
Unknown radio
It's like a stripped McMichael Twin Supervox
I think there was a replica transistor model with similar styling
Unknown radio
Thank You Michael!
It is not this model ... but ...
One can clearly see that the case is quite similar, but the knobs show that there is a different chassis. Also one can see that it is not a cabinet of the Twin Supervox RV8 which was reused but a most similar cabinet. Still:
At present we show 177 models of which 107 show at least one picture for McMichael Ltd. We can see a few twin loudspeaker models, but the one I moved the picture to is the only one which is that similar. Reason: When we have a post sticky to this model - by using the model to do the forum post - this can be detected by a person who looks up the picture gallery and the chance is much higher that we get some more input. We can get answers also from guests who use the bottom-link "contact".
Cordially,
Ernest
Thank You Ernest!
Yes, it's only copied, but I'm nearly sure I saw the commercial transistor based radio.
Ebay 300944554972 by soggyboy89,
Clearly has LW, MW and FM on the scale
Yes it is more like. But the original may be what I asked for, not a copy. approx. I can get the device in 30 days and we'll know more.
According to an old Worthpoint capture of ebay:
The Steepletone NR-1200S is plain, but otherwise similar to the earlier mottled model. Beige wood body and black base. The radio is 153/4" (400mm) wide x 9" (228mm) tall x 53/4" (145mm) deep
See worthopedia/vintage-ww2-1940s-nostalgic-423837816
So the inspiration is likely the McMichael model, but the OP photo is probably of a Steepletone model, perhaps the NR1200 with the finish stripped.
It's not in the 2020 catalogue.
I searched pic-click and past ebay listings.
The model is listed on Amazon, unavailable and no image:
ASIN: B0002DELFA
Date first available at Amazon.co.uk: 16 Mar. 2006
Also found is identical front style on "cash converters" and "worthpoint", but two different finishes:
Steepletone nr-1251 CXF
STEEPLETONE NX1251CXF
There is a car style slot for a cassette on one side.
Probably the X is an error
On Amazon ASIN: B0002DELFK Date first available at Amazon.co.uk: 16 Mar. 2006
But not available and no image.
Cassette version was also on Gumtree last year:
A superb fully working mains powered radio and cassette player. ULTRA Radio 'Radios Richest Choice '. Steepletone Model No: NR-1251 CXF. 20 cm Height 32 cm Width 14 cm Depth Ad ID: 1342416871
Unfortunately, it turned out to be a 1994 replica radio. :(
Attachments:- radio photo (104 KB)
I suspected it was. So Soundmaster is using the same source as the Steepletone models.
