Unknown RCA tube
? Unknown RCA tube
Who knows this RCA tube? Type designation is not readable.
Some informations: height 2 6/8 in., diameter 1 1/8 in. It's a pentode system with B9A base.
Uf = 12.6 volts @ 0.26 amp. at pin 4 & 5, filament is center-tapped at pin 6
Pin 1: K
Pin 2: G1
Pin 3: G3
Pin 4: f
Pin 5: f
Pin 6: fm
Pin 7: A
Pin 8: G2
Pin 9: G3
Any hints are highly appreciated, thank you!
12HG7
The question has been solved in the German speaking forum, the unknown tube is named 12HG7. For me it's unusual that this type has been manufactured in 2 different shapes. The pictured tube is quite thick, but the common dimension (or diameter) is also represented. Do anyone knows the reason for this?
