Unknown RCA tube
? Unknown RCA tube
16.Aug.16 17:02
87
Officer
Articles: 1743
Count of Thanks: 6
Who knows this RCA tube? Type designation is not readable.
Some informations: height 2 6/8 in., diameter 1 1/8 in. It's a pentode system with B9A base.
Uf = 12.6 volts @ 0.26 amp. at pin 4 & 5, filament is center-tapped at pin 6
Pin 1: K
Pin 2: G1
Pin 3: G3
Pin 4: f
Pin 5: f
Pin 6: fm
Pin 7: A
Pin 8: G2
Pin 9: G3
Any hints are highly appreciated, thank you!
12HG7
18.Aug.16 16:37
87 de 3900
Officer
Articles: 1743
Count of Thanks: 8
The question has been solved in the German speaking forum, the unknown tube is named 12HG7. For me it's unusual that this type has been manufactured in 2 different shapes. The pictured tube is quite thick, but the common dimension (or diameter) is also represented. Do anyone knows the reason for this?
