VT25_GPO (VT25_GPO)
This article refers to the component: To the tube/semiconductor
VT25_GPO (VT25_GPO)
07.May.12 11:57
2298
The original version of the VT25 had an American made "Shaw" Navy metal shell UV base with the Shaw logo of an "S " inside a diamond stamped into the base within the pin area. These tubes were tipped. Later tipless versions, c. 1930, had a metal shell Shaw base which was polished nickel plated. The VT39 and VT40 tubes, similar to the later VT25 were also fitted with the polished Shaw base.
