wandel-gol: SPM-3; Selektiver Pegelmesser
? wandel-gol: SPM-3; Selektiver Pegelmesser
25.Mar.12 00:15
37
Don Dorward (CDN)
Articles: 2
Count of Thanks: 7
I recently aquired an SPM-3 in excellent condition, except it does not work on either selective or wideband. Fuses are OK.
Meter pointer jumps when unit is switced on.
I do have the schematics. I wondered if others have had this issue and what the problem was.
I am thinking the input amplifier 1st transistor??
Not sure where to start.
Don
VA3DDN
use adjustment tables
25.Mar.12 12:07
37 de 2825
Pius Steiner (CH)
Articles: 343
Count of Thanks: 8
Dear Mr. Dorward
I do not know the device. First thing I would check the operating voltage. If this voltage is OK, check all voltages according to the scheme, starting from the input of the signal path.
I've uploaded 6 files (adj1-6) to the model. Maybe the adjustment tables helps you further.
best regards
Pius
