zenith:  ; 702
This article refers to the model: 702 (Zenith Radio Corp.; Chicago, IL)
? zenith:  ; 702
05.Nov.10 13:10
55
Ion Carabas (RO)
Articles: 40
Count of Thanks: 10
Ion Carabas
Dear collegues,
  Sometimes, one of us need your help. I am following today.
I found in a deplorable situation a radio device Zenith 702 made in 1934 – in   USA .
I bought from USA a schematic of the electronical parts, wich approved to be identical with the schematic wich appears on Nostalgia .
In the drawing attached , the most resistances are marked with M character. Does somebody knows what this mark represents?
Under the chassis , fixed on the wall with caps, is a wire wound resistance , wich, unfortunately is destroyed. Does somebody knows the value of this resistance and the wats, also its position in the drawing?
I am asking Mr. BIRKNER to reply, because I saw that he has a Zenith 702.
  Thank you,
Best regards,
Ion Carabas  (e-mail address: ion.carabas@coneco.ro) .
? '. M' = K Ohms
06.Nov.10 00:00
55 from 4796
Bryan Spacek (USA)
Articles: 2
Count of Thanks: 11
Bryan Spacek
If you could post a picture of the chassis and the part you need to ID, it would be a big help.
The point before the M has gone lost in the schematic ...
.M (with the point) would be correct for Kiloohms but better and more often used is k or K - and we see here why ...
? 702 unknown resistor
06.Nov.10 08:21
92 from 4796
Articles: 2316
Count of Thanks: 15
Please trace the connections of the resistor to other elements, e.g. tube pins. That should result in a clear allocation in the schematic and consequently the values.
I am currently not in the position to dismantle the set
Good luck,
KoBi
Please upload pictures of the wiring - yet untouched
06.Nov.10 09:15
104 from 4796
Officer
Articles: 5751
Count of Thanks: 12
It is always a big help if members load up photos of the wiring of an untouched set after dismantling. Explanations are then much easier.
Maybe you have not yet changed things and can do so?
Zenith 702 seems having schematic variants.
The official Zenith schematic differs from that we show and possibly also from the Rider's. In case of need I can scan and upload the Rider's schematic. Our SchematicFinder tells us that it is Rider's volume 5 page Zenith 4. I have all of them - but not necessarily the time to help in any case - just if it is necessary.
There are only a very few possibilities for this wire wound resistor (which can be within a small shielded case) but since we don't want to guesswork (cathode resistor of the 75 - if having only two wires), we better wait for the photos - which might help later for other guests or members.
Zenith 702 - reply
09.Nov.10 09:50
258 from 4796
Ion Carabas (RO)
Articles: 40
Count of Thanks: 10
Ion Carabas
Dear Mr.  Ernst,
I have to confess that I did not espect for help so soon from the collegues from Radiomuseum. I had the sensation that I am in a family, emotion wich gave me a spiritualy calm. I will prepare urgently photos.
Thank you,
Ion
photos Zenith 702
10.Nov.10 14:59
345 from 4796
Ion Carabas (RO)
Articles: 40
Count of Thanks: 10
Ion Carabas
Dear collegues,
Please find enclosed pictures of Zenith 702.
Thank you
new manuals
10.Nov.10 17:10
364 from 4796
Heribert Jung (D)
Articles: 1021
Count of Thanks: 16
Hello Ion,
please read my new  thread about the resistors. It makes sense to crop the pictures before reducing to 933 pixel. So you can show more details. Please loade your best pictures direct to the model page.
Regards,
Heribert
Zenith 702
10.Nov.10 17:36
368 from 4796
Bryan Spacek (USA)
Articles: 2
Count of Thanks: 12
Bryan Spacek
  This AC/DC set originally had a resister cord to drop the line voltage to the proper level for the filament string. The old destroyed part on the side of your set is (was) a candohm resister, that was probably part of an earlier attempt to do away with the resister cord so that a modern type input cord could be used.
It is pretty common to run into this with these older sets with resister cords. They can be quite dangerous (fire hazard) with the higher voltages we use today. They were built for 110 volts, but usually today you will get 120 volts and up to 130V. That's too much for those old cords, and they will over heat.
 The large gold resister seems to be a replacement for the destroyed candohm resister. It appears to be between the on/off switch and the filament string. The purpose would be to drop line voltage in place of the resister cord.
  If you could check the line cord for it's resistance value, that should verify this theory. If it has little to no resistance, then we are on the right track. If it is 145 ohms, then the old resister cord is still in place, and we need to go another direction.
Material for resistors
11.Nov.10 12:18
439 from 4796
Ion Carabas (RO)
Articles: 40
Count of Thanks: 13
Ion Carabas
Dear Heribert,
Please tell me where I shall search your material about resistors. In the nearest future I will crop the photos. Please be understable with me, because I manage hard with the computer, because I am 73 years old.
Thank you,
Ion Carabas
M in US schemas or in German schemas
11.Nov.10 12:44
443 from 4796
Heribert Jung (D)
Articles: 1021
Count of Thanks: 11
12.Nov.10 10:50
491 from 4796
Articles: 2316
Count of Thanks: 13
The element in question contains two resistors of 75oo Ohm and 250 Ohm resp., and a capacitor of 0.05 µFas follows:
A - B = 7500 Ohm
B - C = 0.05 µF, in parallel a 10 kOhm resistor E
C - D = 250 Ohm (schematic says 200 Ohm).
Point D is chassis
Note: the cap is not directly connected with chassis ground, as suggested by the schematics!
Here is the configuration as found in my 702 (compare with the "official" schematic):
Good luck
KoBi
Zenith 702 -thank you
12.Nov.10 12:48
515 from 4796
Ion Carabas (RO)
Articles: 40
Count of Thanks: 12
Ion Carabas
Dear Kobi,
Now everything is clear. Thank you and I wish to you healthy.
Ion
Zenith schematic
17.Nov.10 11:02
581 from 4796
Ion Carabas (RO)
Articles: 40
Count of Thanks: 14
Ion Carabas
Thank you for the schematics.
I observed that something is missing and that is  the value of the condenser marked with the green circle.
Capacitor
17.Nov.10 14:26
606 from 4796
Articles: 2316
Count of Thanks: 11
