ZM1410 (ZM1410)
This article refers to the component: To the tube/semiconductor
ZM1410 (ZM1410)
18.Feb.14 13:43
2197
Carlos Saavedra (E)
Count of Thanks: 11
Count of Thanks: 11
ZM1410 & ZM1412 Nixie tubes are (in Siemens April 72 Catalogue) 8.6mm Symbol Height 7-segment single digit plus upper-left and lowe-right dots nixie tubes.
The base is a 12-pin subset of 14-pin SK-207
Pin assignments:
1 K seg 'b'
2 i.v.
3 K seg 'd'
4 K seg 'c'
5 K seg 'j' (lower-right dot)
6 Anode
7 Anode
8 K seg 'e'
9 K seg 'g'
10 K seg 'a'
11 K seg 'f'
12 Kseg 'k' (upper-left dot)
Regards,
Carlos Saavedra
